< Noticias ~ LightWave Free update |
MiguelS |
Colocada: Ter Jul 26, 2005 6:57 am |
*New OpenGL Hardware shader option using the hardware renderer in OpenGL video cards to display many of the render functions in real-time. Lights, light falloffs, blending images on surfaces, per-pixel lighting will all be available in real-time, with an option to turn this feature on and off.
*New Parts-to-Surfaces tool allows for easier integration of 3D objects created in other applications.
*New Multi Shift allows the user to do multiple shifts in a single edit with a history profile that can be saved and applied to other meshes."
*Dynamics now launch a control window that allows you to switch to other applications while calculating dynamics in LightWave.
*Particle dynamics have been improved for accuracy, including interaction with collision planes. A new algorithm also allows large dynamic scenes to load up to 10x faster.
*104 new configurable keyboard shortcut options.
http://www.newtek.com/products/lightwave/downloads/updates/lw83/index.html |
