<  Geral  ~  is it an act of terrorism ?
Guybrush
Colocada: Qua Set 13, 2006 5:57 pm Responder com Citação
Primeiros passos Registo: 28 Jan 2005 Mensagens: 137
uma coisa que convenientemente nao falam neste artigo, é o que aconteceu ás asas, se o aviao entrou 3 aneis como eles afirmam, axo k as asas deviam ter atingido o edificio, mesmo k seja de concreto, a 400km/h qualquer coisa deixa marca.
fonziewonzie
Colocada: Qua Set 13, 2006 6:07 pm Responder com Citação
sigh...
entao agora le este artigo:
http://www.ctv.ca/servlet/ArticleNews/story/CTVNews/20060906/911_Conspiracy_060906/20060910/
"According to the ASCE report, neither wing actually penetrated the building, because they were damaged before the plane hit the outer facade. Flight 77 hit the ground before the Pentagon, and much of its left wing likely ripped off or was badly damaged. When it crashed into the building, the other wing shattered on impact, along with the front of the plane.
It was actually the rear body of the plane that passed through the building, after the front opened up a hole. What continued into the Pentagon after the impact were the end sections of the fuselage and the landing-gear -- heavy equipment that must necessarily be durable enough to carry tons of steel as the plane touches down on a runway. The black box, also located near the back of the plane, was recovered from deep inside the building."
.: a
Colocada: Qua Set 13, 2006 9:28 pm Responder com Citação
Yap, as teorias do site abovetopsecret tb estao correctas...
Acho que me deixaram até 50/50 relativamente se foi um aviao ou um missil. As teorias sao de peso para ambos os lados... mas o que deixa um gajo a pensar é, que se foi um missil... entao onde estao os tripulantes do voo 77? Confused
Outra coisa:
fonziewonzie escreveu:
Flight 77 hit the ground before the Pentagon, and much of its left wing likely ripped off or was badly damaged. "
If Flight 77 had crash landed, and skidded into the Pentagon...
It would have looked like this.
Instead, it looked like this, without a single scratch on the lawn.
fonziewonzie
Colocada: Qua Set 13, 2006 9:41 pm Responder com Citação
eles nao dizem crash landed. dizem q por acaso bateu no chao antes d atingir o building. ha varias provas q isto aconteceu nomeadamente:
Area of fence to the right of the impact area partially flattened by the right engine of the plane. Note how a couple of the poles are bent right over, some are sheered off at the top, yet the pole and fence portion on the left is untouched (obviously the right engine took out the fence to the right of those poles) and the entire back side of the fence has been torn away. The generator was hit by the right wing and engine before the 757 hit the building - the damage is evidenced by other photos of the crash area.
e as pessoas estavam la. dna samples foram tirados do crash scene e ligados aos familiares das vitimas.
eh completamente ridiculo imaginar q nao havia gente a bordo do aviao, ou q dezenas de familiares inventarem a morte de familiares numa tragedia como estas.
.: a
Colocada: Qua Set 13, 2006 9:44 pm Responder com Citação
Eu mto sinceramente espero que assim seja...
Não sabia dessa do DNA, isso muda mta coisa.
ultra
Colocada: Qua Set 13, 2006 11:11 pm Responder com Citação
Roflt! fonziewonzie tás um verdadeiro americano!
TETRA CAMPEÃO!
fonziewonzie
Colocada: Qua Set 13, 2006 11:23 pm Responder com Citação
por acaso ate sou americano ;)
.: a
MALicivs
Colocada: Qui Set 14, 2006 8:19 am Responder com Citação
Já faz sozinho Registo: 23 Mar 2005 Mensagens: 397 Local/Origem: Estoril
nao se esqueçam de como eles nao conseguiram recuperar quaisquer destroços do aviao pk dizem que foram incinerados pelo querosene, mas conseguiram identificar 184 corpos...
dabliu tê éfe?
http://www.ididitforthepoly.com/
Guybrush
Colocada: Qui Set 14, 2006 11:52 am Responder com Citação
"First, the impact of the planes damaged the buildings' structural integrity. The south tower was hit second but was the first to collapse, because Flight 175 hit the building's corner, creating a major imbalance. Flight 11 hit the middle of the north tower, leaving the corners in far better shape."
incrivelmente se analisarem os projectos do WTC poderam ver k a estruturdo edificio é feito pelo centro do edificio, k é onde estao todas as colunas de sustentação, aproveitando as caixas de elevadores escadas e afins...e a desculpa de a torre sul cair primeiro, é porque o aviao lhe bateu no canto?! por favor....
tbem gostei da teoria do aviao bater primeiro no xao e perder uma das asas, se uma das asas nao entrou no pentagono, então onde está?, tambem se vaporizou com as altas temperaturas que foram incapazes de carbonizar os corpos e respectivos dna´s ,e um passaporte?
e peço desculpa, mas a teoria que " nos retiramos 60´s pessoas dos destroços e comparamos dna´s" se o ataque tivesse sido orquestrado pelo governo americano ( eu nao digo que foi, apenas digo que as justificações deles nao fazem sentido) , inventar isso seria o mais facil, bastava destruirem o verdadeiro aviao noutro sitio.
existe tbem a questao do avião heroico que ja teve direito a filme, que caiu no meio de uma floresta, mas desapareceu logo a seguir.
ricardo_sousa11
Colocada: Qui Set 14, 2006 12:31 pm Responder com Citação
200 pessoas foram mortas no pentagono...agora..quantas pessoas iam no aviao ? quantas pessoas eram supostas tarem nakele lugar do pentagono...na minha opiniao 1 boeing 757 fazia mt + damage...eu achop que foi o missil..e nao e estupido pensar que o aviao ia vazio...as chamadas dos avioes que embateram nas torres eram falsas..e na pensylvania nao avia sangue..e se fosse msm 1 boeing...nao evaporava...tao rapidamente..ao -...e iam aparecer mt + pessas do boeing..era impossivel desaparecer e como ja foi dito o chapo nao ta danificado..acho que ja temos todos provas suficientes para podermos dizer que foi propositado...e pelos eua...a torre 7 que nao lhe calhou nada tambem caiu..e se repararem 1 das torres cai em direito mas fica de lado enquanto cai...talvez a intensao era de cair na torre 7 e falhou...nao sei...se calhar e so + 1 teoria...mas que tudo ta mal explicado ta..e que nao ha ninguem + poderoso no mundo do que o bush para levar o governo dos EUA a tribunal para responder a umas perguntinhas..se estas teorias estiverem correctas...podemos considerar que o governo dos EUA=Hitler...ambos matam,e ambos criam 1 guerra sem razoes nenhumas..
rcas
Colocada: Qui Set 14, 2006 12:35 pm Responder com Citação
Não vale a pena ser assim, a verdade é que o Bin Laden contratou o Copperfield para fazer desaparecer os aviões, o problema foi que ele não pode ficar até ao final por causa de outra actuação, logo ficou o rasto ...
Eu continuo a achar que o governo meteu o dedinho, ou talvez a mão toda nisto. E continuo a achar que o que embateu no Pentágono foi outra coisa que não um avião. Testemunhos é do mais fácil de arranjar (aja dinheiro) e as provas fáceis de forjar, ainda para mais em terreno do Pentágono, minha nossa... O que se vê de destroços parecem ser pedaços cuidadosamente deixados aqui e ali para que se possa dar a ilusão de ser um avião, pelo menos eu assim acho.
Quanto às pessoas que misteriosamente desapareceram, pode ser por muitas razões, Programa de Protecção de testemunhas, que melhor aparato para fazer desaparecer estas pessoas ? Espiões ou outros individuos demais que necessitassem de ver as suas entidades apagadas ...
Mas pronto, uma vez que eles eliminaram as provas nunca vai ser possível confirmar nada, a não ser quando ficarem velhos e com remorços e venham contar a verdade, mas nessa altura já é tarde.
Blender 3D all the way.
http://www.blender3d.org
fonziewonzie
Colocada: Qui Set 14, 2006 10:14 pm Responder com Citação
malicivs: a maior parte dos corpos penso q foram identificados com DNA q eh mto mais facil d encontrar num crash site q propriamente corpos inteiros. e foram encontradas varias pecas do aviao, incluindo as black boxes q so nao foram publicados os conteudos por respeito aos familiares das vitimas (q acho mto bem). outras pecas d aviao q foram encontradas incluem partes da engine, da cauda, dos pneus e jantes, etc etc.
guybrush: ja houve varias simulacoes de fisicos conceituados q provam completamente q o facto de o aviao ter atingido o canto do edificio provocou um imbalance mto mais forte na estrutura do edificio q na outra torre. simulacoes essas q tb provaram q os danos causados a ambas as estruturas seriam suficientes para causar o destronamento do edificio inteiro. qto ah asa, ja comentei em cima. parte dos destrocos foram ditos estar relacionados com as asas. existem diversos reports q comprovam isso, por isso usa o google q eu ja tou farto de andar a por aqui links. eh completamente absurdo achar q o governo seria capaz de organizar uma conspiracao d grande escala ao ponto de ter dezenas d familias a fingirem q tiveram pessoas mortas no aviao, mais a local police, firefighters e coisas do genero. por varias razoes, entre as quais o governo americano nao seria inteligente ao ponto d conseguir coordenar semelhante coisa. mas as mais obvias, sao mesmo, seria logisticamente impossivel meter agencias locais em termos d policia, investigadores, companhias aereas, familias normais, hospitais, medicos, advogados, tudo e mais alguma coisa, ao ponto d estas mesmo aceitarem uma conspiracao do tamanho q vcs estao para aqui a imaginar. se vos parece ser facil eh porque andam a ver filmes a mais, nunca vieram aos USA e nao fazem a menor ideia como o governo federal e estatal eh aqui organizado.
ricardo_sousa: antes pelo contrario nao ha uma unica prova q denuncie os crashes dos avioes serem falsos. tas a basear a tua ideia em teorias d conspiracao completamente despropositadas. claro q ha duvidas e incertezas em relacao a determinadas coisas, mas os avioes estavam bastante cheios (le os artigos q ja linkei aqui). o resto das torres terem caido ta explicado cientificamente pelas leis da fisica e thermodynamics em varios artigos publicados online. again, google is your friend. por favor procura e estuda antes d formares uma opiniao sem bases. existem mtos problemas neste pais, o bush e a administration dele so aldrabam e fazem mal a toda a gente, mas peco-te q nao compares o bush ao hitler. concordo q seja sinistro e completamente desumano o q o bush esta a fazer no iraq, ah quantidade de pessoas inocentes q estao a morrer por uma guerra sem fundamento. mas comparar o bush com uma ditadura d extrema direita e um genocidio como o q aconteceu no holocausto, nao tem senso. felizmente, a populacao americana ainda tem alguma voz no meio disto tudo e a situacao politica esta a mudar aos poucos aqui.
rcas: respeito q tenhas a tua opiniao, mas qdo varios peritos em acidentes d viacao identificam e comprovam d imediato q um acidente como o do pentagono eh perfeitamente causado pela queda de um boeing e nao d um missil, eh um bocado dificil para mim duvidar isso. peco-te q leias mais reports q estao disponiveis na internet sobre precisamente isto. os q eu referi antes sao apenas um start.
d resto, so deixo aqui a couple of more things.
1. nao sei mto bem o q este thread tem a ver com a galeria 3d.
2. in spite of that, deve ser dos threads mais interessantes q por aqui passou. qto mto pq fico curioso em ver q tipo d reaccao outros portugueses tem em relacao ao q s passa nos USA.
3. sou democrata e nao concordo com 99.99% das accoes ou beliefs q o bush e sua administration tem.
.: a
fonziewonzie
Colocada: Qui Set 14, 2006 10:21 pm Responder com Citação
outro artigo...
http://www.popularmechanics.com/science/defense/1227842.html?page=6&c=y
.: a
MALicivs
Colocada: Sex Set 15, 2006 12:18 am Responder com Citação
fonziwonzie desculpa lá, DNA? quer dizer os motores feitos de titanio fundiram-se completamente, e DNA que é basicamente... carbono, conseguiu sobreviver às temperaturas?
fonziewonzie
Colocada: Sex Set 15, 2006 12:20 am Responder com Citação
vou voltar a repetir... partes dos motores FORAM encontrados. ha provas fotograficas disto mesmo e varios peritos d aviacao e d air crashes o confirmaram tb.
e dna foi encontrado por varias razoes, uma das quais houve varios human remains q foram recuperados imediatamente apos o acidente.
e ja agora, aqui vai mais um link e uma quote do site.
http://usinfo.state.gov/media/Archive/2005/Jun/28-581634.html
Passenger and Crew Remains Recovered at Pentagon Crash Site
In addition to the numerous eyewitness accounts, the remains of the passengers and crew onboard American Airlines flight 77 were recovered from the Pentagon crash site. A team of more than 100 forensic specialists and others identified 184 of the 189 people who died in the Pentagon attack (125 from the Pentagon and 64 onboard American Airlines flight 77). All but one of the passengers onboard American Airlines flight 77 was positively identified as a match with DNA samples provided by the families of the crash victims. These positive forensic identifications provide irrefutable proof that American Airlines flight 77 crashed into the Pentagon on September 11. In addition, rescue and recovery personnel at the Pentagon reported seeing the bodies of airline passengers. The September 14, 2001 edition of USA Today reported, "When [Army Sergeant Mark] Williams discovered the scorched bodies of several airline passengers, they were still strapped in their seats."
Plane Debris Found at Pentagon Crash Site
People who went to the Pentagon crash site reported seeing parts of an airplane, including the nose cone, landing gear, an airplane tire, the fuselage, an intact cockpit seat, and the tail number of the airplane, as reported in an e-mail to a conspiracy theory website that debunks the conspiracy theory claims. The e-mail also contains photographs of airplane landing gear, tires, and fuselage fragments, which were taken at the Pentagon crash site. Moreover, the black boxes for American Airlines flight 77 were found at the Pentagon crash site.
e ainda outro link a sumarizar as conspiracy theories todas com ainda mais links para seguir.
http://usinfo.state.gov/xarchives/display.html?p=pubs-english&y=2006&m=August&x=20060828133846esnamfuaK0.2676355
.: a
yen3D
Colocada: Sex Set 15, 2006 8:49 am Responder com Citação
oi...
Isto não deveria estar na secção Geral?
Nunca tinha visto nada sobre estas conspirações. Tive a ver ontem na rtp2 um documentario... acho que era a repetição do que deu no outro dia.
O que me despertou mais duvidas nem foi essas partes de DNA ou se as torres cairam por causa do fogo.
Falou-se de coisas para mim muito mais suspeitas: A compra de acções na bolsa, movimentações bancarias e telefonemas a pessoal do governo a dizer para eles não andarem de avião naquele dia..... é estranho sim senhor.
Mas em quem é que vamos acreditar?
um acto do governo ou terrorismo? não sei! mas sempre que revejo as imagem do 9/11 fico estremamente impressionado.
Os USA são o autoproclamado país da liberdade mas cada vez mais isso é uma ilusão pois com isto tudo o controlo sobre o povo é maior do que nunca.....até parece que se está a caminhar para uma ditadura camoflada.
E talvez não seja so nos US...
espero que este mandato do Bush seja o seu ultimo... ou melhor, da administração Bush.
bem... por mim ja chega das coisas do 11 de setembro... lets talk about CG Smile
||yen3d||
rcas
Colocada: Sex Set 15, 2006 10:06 am Responder com Citação
Como é normal cada um tem a sua opinião e respeito as dos outros, em especial quando não existem provas irrefutáveis e num assunto rodeado de pormenores duvidosos.
Mas para mim isto não foi feito por um avião:
Se tivesse sido para mim o buraco ou tinha sido maior, ou então mais pequeno, os destroços não iriam parar a centenas de metros, mas por ali perto. E ainda, uma das asas supostamente não saltou fora, logo, deveria ter atingido o edifício e pelo menos deixar algum resticio, uma amostra. O que se vê ali claramente não tinha as asas ...
Mas pronto, acho que realmente isto não vai dar em nada e que devemos é dedicar-nos ao CG como o yen3D disse.
Have fun.
-- Rui --
Página 2 de 3
Ir à página Anterior  1, 2, 3  Seguinte
