Colocada: Sex Jul 28, 2006 11:56 pm |
Vou dedicar um topic à Siggraph 2006 que vai ser realizada em Boston.
Pretendo colocar aqui todos os links com noticias e outros goodies deste evento. Agradecia que se tivessem links ou apenas noticias o fizessem neste tópico. |
Editado pela última vez por flash em Qua Jun 27, 2007 6:42 pm, num total de 1 vez |
Colocada: Sáb Jul 29, 2006 12:00 am |
A boxx anunciou recentemente que vai apresentar novas maquinas a correrem a 64 bits, incluindo o OS, produtos da autodesk. Tb houve uma leek de informação em que a autodesk ia apresentar nestas mesmas maquinas o maya 8 e o max 9.
http://www.boxxtech.com/news/events.asp |
Colocada: Sáb Jul 29, 2006 12:04 am |
Colocada: Seg Jul 31, 2006 6:25 pm |
Isto anda fraco de noticias, mas já andam ai umas leaks sobre o maya 8 e max 9.
3ds Max 9
General productivity
It is for the first time presented two versions: for the 32- bit and 64- bit version Windows.
Optimization in these regions:
- mapping shell with the editing is optimized for DirectX
- soft isolation in the regime of the editing of the apexes
- mapping surfaces in the regime of apexes and edges is optimized for DirectX
- is optimized mapping splines
- is optimized the system of input/output of the scanning images
- the syntactic analysis XAF and the conversion of scenes mental ray
- I much is other.
Productivity
The basic tools of animation and renderinga in 3ds max 9 possess larger speed and accuracy.
Partition of animation into the layers
Improved integration with Biped, including
- separate tracks for it is finger legs and hands;
- the support of all types of tangents;
- the possibility to establish keys in the opposite direction (for the work with the negative personnel and the clips in the opposite direction)
Improvements in module Hair:
- the creation of hair-dos directly in the window of the projection
- the support of all luminous sources and types of the shadows
- improvements into the visualizations, which make it possible to be achieved the best results in the shorter time
- the support of the connected visualizers
Improvements in module Cloth
Improvements in visualizer mental ray:
- the improved option of final assembling (Final gather)
- Sheydery for creating of clouds and sky
- Sheydery for the imitation of automobile paint (Car paint)
- materials for the design and the architectural visualization
Improvements in the command work on the project
In Autodesk 3ds max 9 are introduced the changes, which give the possibility to increase the effectiveness of command work. In particular, it began be exchanged to more easily files, to track working copies, to introduce correctives into the production.
Intellectual system of point keshirovaniya
Improvements in the universal size FBX
Support of the relative ways
Support Autodesk Vault 5 improvement in it, among which
- the support of the 64- bit operating systems
- the support of folders with the libraries
- improvements in SDK
Improvements in the work with the command line and language Maxscript
Support of all sheyderov DirectX and improvement in the productivity
Additional possibilities of work with the external references (X -ref) and the support
- Biped
- controller PRS
- the animations
Isto nao passam de rumores por enquanto. Mas já se pode tirar uma ideia do que vai ter. |
Colocada: Seg Jul 31, 2006 6:26 pm |
Colocada: Seg Jul 31, 2006 7:34 pm |
Colocada: Seg Jul 31, 2006 7:56 pm |
Colocada: Ter Ago 01, 2006 1:15 am |
Colocada: Ter Ago 01, 2006 1:43 am |
pedroamorim |
Colocada: Ter Ago 01, 2006 3:15 am |
Registo: 23 Dec 2005
Local/Origem: Gondomar
muito bem. tas a fazer um bom trabalho jornalistico.  |
_________________ Pedro Amorim
Entretainer, domador de leões e bon vivant. |
Colocada: Ter Ago 01, 2006 7:24 am |
spurv3d |
Colocada: Ter Ago 01, 2006 8:53 am |
Local/Origem: Carnaxide - LX
spurv3d |
Colocada: Ter Ago 01, 2006 9:04 am |
Colocada: Ter Ago 01, 2006 11:05 am |
Colocada: Ter Ago 01, 2006 11:18 am |
Uma nova tecnologia interessante. Vão à secção verse.
Basicamente é uma libraria que permite a transmissão de modelação 3d em tempo real
http://www.quelsolaar.com/ |
Colocada: Ter Ago 01, 2006 11:48 am |
Colocada: Ter Ago 01, 2006 12:35 pm |
Citação: Uma nova tecnologia interessante. Vão à secção verse.
PS: Desenvolvido em cooperação com a Blender Foundation, com uma versão do Blender disponível para Download faz já quase um ano com essa tecnologia integrada .... |
